/TH/SENSOR
Block Format Keyword Describes the time history for sensors.
| /TH/SENSOR/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
Definition
| thgroup_ID | TH group identifier. (Integer, maximum 10 digits) |
| thgroup_name | TH group name. (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for TH (see table
below). (Character, maximum 8 characters) |
| Obj_ID1, ...n | Identifiers of the objects to be
saved. If Obj_ID1 =0, all objects available in the model are added in the time history. (Integer) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| SENSOR | sensors | STATUS |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| SENSOR | DEF | STATUS |
Output of Sliprings
- STATUS: Sensor status:
- 0
- Sensor is deactivated.
- 1
- Sensor is activated.
