/TH/SLIPRING
Block Format Keyword Describes the time history for sliprings.
/TH/SLIPRING/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
Obj_ID1 Obj_ID2 Obj_ID3 Obj_ID4 Obj_ID5 Obj_ID6 Obj_ID7 Obj_ID8 Obj_ID9 Obj_ID10
Definition
thgroup_ID TH group identifier
(Integer, maximum 10 digits)
thgroup_name TH group name
var_ID1, ...n Variables saved for TH. See TH Output Keywords & Variables.
(Character, maximum 8 characters)
Obj_ID1, ...n Identifiers of the objects to be saved
(Integer)
TH Output Keyword & Variables
Keyword Object Saved Variables
SLIPRING Sliprings RINGSLIP, FN, F1, F2, THETA, GAMMA
Table of Available Variables - Part 2
Keyword Variable Group Saved TH Variables
SLIPRING DEF RINGSLIP, FN, F1, F2, THETA, GAMMA
Output for Sliprings
  • RINGSLIP: total amount of material crossing the slipring
  • FN: normal force on slipring
  • F1: axial tension in strand 1 of the slipring
  • F2: axial tension in strand 2 of the slipring
  • THETA: angle between slipring strands
  • GAMMA: orientation angle of the seatbelt
  1. The slipring is positive when the material moves from elem1 to elem2 and is negative if the flow of material is in the opposite direction.
