*INITIAL_STRESS_SOLID
LS-DYNA Input Interface KeywordInitializes the stress for solid elements in the global coordinate system.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *INITIAL_STRESS_SOLID | |||||||
| EID | npg | LARGE | |||||
If LARGE = 0
| SIGXX | SIGYY | SIGZZ | SIGXY | SIGYZ | SIGZX | EPSP | SIGXX |
If LARGE = 1
| SIGXX | SIGYY | SIGZZ | SIGYZ | SIGZX | |||||
| SIGZX | EPSP | ||||||||
Definition
| EID | Solid element
identifier. (Integer) |
| SID | Part set
| npg | Number of Gauss integration points.
(Integer) |
| LARGE | Format size.
(Integer) |
| SIGij | Stress value in the direction
ij. (Real) |
| EPSP | Plastic strain. |
- This keyword maps to /INIBRI/STRS_FGLO.
- For 8 integration points, the Gauss integration points are stored in
the following order:
