/INIQUA/DENS
Block Format Keyword Describes the initial state for a quad.
/INIQUA/DENS/unit_ID
quad_ID value
Definition
unit_ID Optional unit identifier.
(Integer, maximum 10 digits)
quad_ID Element identifier.
(Integer)
value Data value.
(Real)
  1. The initial state for quad may be defined by more than one block.
