/H3D/NODA
Engine Keyword Generate H3D contour output results for nodes.
/H3D/NODA/Keyword3/Keyword4
#optional next line(s) that lists the parts to save results for.
part_ID1 ... part_IDN
Definition
Keyword3 Output types.
Keyword4 Output types.
part_IDN Optional list of part IDs for which results will be output.
Table 1. Scalar Output
Keyword3 Keyword4 Description
CSE_FRIC None Nodal surface contact frictional energy (sum of all interfaces energy per unit of area).
Not available for Edge to Edge contact.
INTER=
I or ALL
Nodal surface contact frictional energy for the defined interface (energy per unit of area).
CSE_FRICG Nodal surface contact frictional energy (sum of all interfaces energy per unit of area).
DAMA2 Damage for TYPE2 interface. 2
DENS Element density extrapolated to attached nodes for 3D ALE and FVM nodes of external and internal airbag surfaces.
DINER Nodal inertia change 3
DMASS Nodal mass change. 4
DT Nodal time step
ENER Element specific energy reported to node
GPS1 P Element pressure extrapolated to node
VONM Element von Mises stress extrapolated on node
MASS Nodal mass
NDMASS Non-diagonal mass variation (see time step control /DT/AMS). 5
NVAR1, NVAR2, ...NVAR5 Nodal Variable 1, 2 …5
P Element pressure extrapolated to attached nodes for 3D ALE and FVM nodes of external and internal airbag surfaces.
PEXT External pressure.
SKID_LINE
INTER=
I or ALL
This option is available for /INTER/TYPE8 and /INTER/TYPE21.
For /INTER/TYPE21, it is the maximum over time of the ratio between tangential force F t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamOramaaBaaaleaacaWG0baabeaaaaa@3BC6@ and the limit tangential force F t = P s k i d S 3 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamOramaaBaaaleaacaWG0baabeaakiabg2da9iaadcfadaWgaaWc baGaam4CaiaadUgacaWGPbGaamizaaqabaGccqGHflY1daWcaaqaai aadofaaeaadaGcaaqaaiaaiodaaSqabaaaaaaa@45AA@ . Refer to /INTER/TYPE21 to define Pskid.
= 0.0
If no sliding or contact
= F t P s k i d S 3 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba WaaSaaaeaacaWGgbWaaSbaaSqaaiaadshaaeqaaaGcbaGaamiuamaa BaaaleaacaWGZbGaam4AaiaadMgacaWGKbaabeaakiabgwSixpaala aabaGaam4uaaqaamaakaaabaGaaG4maaWcbeaaaaaaaaaa@44B4@
If sliding and F t P s k i d S 3 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamOramaaBaaaleaacaWG0baabeaakiabgsMiJkaadcfadaWgaaWc baGaam4CaiaadUgacaWGPbGaamizaaqabaGccqGHflY1daWcaaqaai aadofaaeaadaGcaaqaaiaaiodaaSqabaaaaaaa@4659@ . Output will be between 0 and 1.
= 1.0
If sliding and F t > P s k i d S 3 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamOramaaBaaaleaacaWG0baabeaakiabg6da+iaadcfadaWgaaWc baGaam4CaiaadUgacaWGPbGaamizaaqabaGccqGHflY1daWcaaqaai aadofaaeaadaGcaaqaaiaaiodaaSqabaaaaaaa@45AC@ .
For /INTER/TYPE8, drawbead output values are:
= 0
No contact.
= 1.0
Main node is in contact with a drawbead.
SSP Nodal sound speed (FVMBAG)
STIF Nodal translational stiffness
STIFR Nodal rotational stiffness
TEMP Nodal temperature for thermal exchange or element temperature extrapolated to attached nodes for 3D ALE and FVM nodes of external and internal airbag surfaces.
VFRAC Nodal Volumetric Fraction averaged from the attached element. Only ALE multi-material laws (LAW37, LAW51 and LAW151).
Table 2. Vector Output
ACC Node acceleration
AROT Rotational acceleration
Idrot=1 must also be set in /IOFLAG; otherwise, rotational degrees of freedom (DOF) are not computed, and this option is ignored.
CLUSTER FORCE
MOMENT
Spotweld /CLUSTER force or Moment vector in global coordinates
CONT Node contact forces
MAX Maximum nodal contact forces over time
CONT2 Tied interface contact force (/INTER/TYPE2)
TMAX Maximum over time of tied interface contact force (/INTER/TYPE2)
TMIN Minimum over time of tied interface contact force (/INTER/TYPE2)
DIS Node displacement
TMAX Maximum node magnitude of displacement vector over time
DROT Node rotation
Idrot= 1 must also be set in /IOFLAG; otherwise, rotational degree of freedom (DOF) are not computed, and this option is ignored.
FEXT External force
FINT Internal force
FOPT Forces or Moments for rigid bodies, rigid walls and sections.
FRES Residual force (FEXTFINT)
FREAC Reaction forces for imposed velocities, displacements, accelerations and boundary conditions.
FVEL Gas velocity vectors for fluid flow in Finite Volume Method monitored volume, /FVMBAG1.
MREAC Reaction moments for imposed velocities, displacements, accelerations and boundary conditions.
PCONT Normal or tangential contact pressure. 6
TMAX Maximum over time of normal or tangential contact pressure.
PCONT2 Normal or tangential tied contact pressure. 6
TMAX Maximum over time of normal or tangential tied contact pressure.
TMIN Minimum over time of normal or tangential tied contact pressure.
SHELL_OFFSET Displacement vector from the current mesh towards the mid-surface of the shell (used with Ioffset=1 in /DEF_SHELL card).
VEL Node translational velocity
TMAX Maximum magnitude of node translational velocity vector over time
GRID ALE grid translational velocity
VROT Rotational velocities
Table 3. Tensor Output
GPS Mean nodal stress tensor calculated from the element shape functions. 7
Only available for solid elements with /PROP/TYPE6 (SOL_ORTH), /PROP/TYPE14 (SOLID), /PROP/TYPE20 (TSHELL), /PROP/TYPE21 (TSH_ORTH) and /PROP/TYPE22 (TSH_COMP)
TMAX/N=I Mean nodal stress tensor calculated from the element shape functions (7) corresponding to the maximum principal stress (P1) over time.
Mean nodal stress tensor calculated from the element shape functions (7) corresponding to the minimum principal stress (P3) over time.
Only available with solids elements with /PROP/TYPE6 (SOL_ORTH), /PROP/TYPE14 (SOLID), /PROP/TYPE20 (TSHELL), /PROP/TYPE21 (TSH_ORTH) and /PROP/TYPE22 (TSH_COMP).
The option N=I allows the maximum stress to be computed only every I cycles to reduce the CPU time. By default, N=10.
GPSTRAIN Mean nodal strain tensor calculated from the element shape functions. 7
TMAX/N=I Mean nodal strain tensor calculated from the element shape functions (7) corresponding to the maximum principal strain (P1) over time.
Mean nodal strain tensor calculated from the element shape functions (7) corresponding to the minimum principal strain (P3) over time.
The option N=I allows the maximum strain to be computed only every I cycles to reduce the CPU time. By default, N=10.
GPS1 Not recommended - use /H3D/NODA/GPS.
Mean stress of elements connected to node. Only available for /BRICK and /TETRA4.
The stress of the corner node is extrapolated from mean stress at integration point in all elements which are connected to this node.
GPS2 Not recommended - use /H3D/NODA/GPS.
Mean (using relative element volume) stress of elements connected to node. Only available for /BRICK and /TETRA4.
The stress of the corner node is extrapolated from the stress at the integration point.
Node velocity vectors
/H3D/NODA/VEL
Contact pressure for only parts IDs 356 and 293.
/H3D/NODA/PCONT
356 293
  1. When PART IDs are listed after the /H3D/NODA line the specified results will only be output for those parts.
  2. DAMA2 damage percentages for /INTER/TYPE2 with rupture (Spotflag = 20, 21, or 22):
    min ( 100 , 100 n o r m a l r e l a t i v e d i s p l a c e m e n t max n o r m a l r e l a t i v e d i s p l a c e m e n t )
    min ( 100 , 100 tangent r e l a t i v e d i s p l a c e m e n t max t a n g e n t r e l a t i v e d i s p l a c e m e n t )
  3. D I N E R = ( I n e r t i a ( t ) I 0 I 0 )
    Where,
    I 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamytamaaBa aaleaacaaIWaaabeaaaaa@37AE@
    Nodal inertia at the beginning of the current run
    I n e r t i a ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba Gaamysaiaad6gacaWGLbGaamOCaiaadshacaWGPbGaamyyamaabmGa baGaamiDaaGaayjkaiaawMcaaaaa@42C9@
    Current inertia
  4. D M A S S = ( Δ M M 0 ) with Δ M = M M 0
    Where,
    M 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamytamaaBa aaleaacaaIWaaabeaaaaa@37AE@
    Nodal mass at the beginning of the restart.
    M MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@
    Current mass.
    Note: Δ M is re-set to 0 at the beginning of each restart file.
  5. When /DT/AMS is used, a non-diagonal mass matrix is used to increase the time step. On each line of the mass matrix, the lumped mass M 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamytamaaBa aaleaacaaIWaaabeaaaaa@37AE@ is increased with some value Δ M which is compensated with non-diagonal terms such that the total mass to remain constant.
    N D M A S S = ( Δ M M 0 )
  6. For PCONT or PCONT2, two nodal vectors are output:
    P n = F n S , P t = F t S
    Where,
    F n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWG0baabeaaaaa@37EA@
    Sum of normal contact forces applied to the node
    F t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWG0baabeaaaaa@37EA@
    Sum of tangential contact forces applied to the node
    S MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@
    Extrapolated surface of segments connected to the node
  7. The stress or strain of the corner node is computed using bilinear extrapolation of the shape function from stress or strain at integration points of each element which are connected to this node. For thick shell properties, bilinear extrapolation is computed using integration points of upper and lower layers.
  8. /ANIM/NODA/PEXT is computed by averaging the element pressures from load cases (such as /LOAD/PBLAST, /LOAD/PFLUID, etc.) and then projected them onto the nodes by averaging over the connected faces.
