/H3D/QUAD
Engine Keyword Generate H3D contour output results for /QUAD quad elements.
/H3D/QUAD/Keyword3/Keyword4/Keyword5
#optional next line(s) that lists the parts to save results for.
part_ID1... part_IDN
Definition
| Keyword3 | Output types. | |
| Keyword4 | Output types. | |
| Keyword5 | Output types. | |
| part_IDN | Optional list of part IDs for which results will be output. |
| Keyword3 | Keyword4 | Description |
| BULK | Artificial Viscosity | |
| DAM1, DAM2, DAM3 | Principal damage values in local cracking skew direction 1, 2 or 3 for material LAW24 with /QUAD elements | |
| DENS | Density | |
| DT | Time step | |
| EINT | Internal energy ( eV) | |
| EINTM | Specific internal energy (e) | |
| EINTV | Internal energy density ( e) | |
| ENTH | Enthalpy (e+pV) | |
| ENTHM | Massic enthalpy (e + pV) / m | |
| ENTHV | Enthalpy density (e/V +p) | |
| EPSP | Mean element plastic strain (or plastic work for /MAT/LAW15 and /MAT/LAW25) | |
| FAILURE | ID= fail_ID or ALL (mandatory) MODE = I or ALL |
Damage of a specific failure
criterion references by its optional identifier fail_ID defined in the Starter file. (for MODE output, refer to Comment 4) |
| GROUP | Internal group identifier | |
| HOURGLASS | Hourglass energy per mass unit | |
| OFF | Element status. Where the result output is:
| P | Pressure | |
| SIGEQ | Equivalent stress based on a material’s yield criteria. Some examples of yield criteria are von Mises, Hill or Barlat. | |
| SIGX,SIGY,SIGZ, SIGXY,SIGYZ,SIGZX | Mean element stress in specified direction. | |
| TILLOTSON | Region identifier for Tillotson Equation of State (/EOS/TILLOTSON) | |
| TSAIWU | Tsai Wu criterion for /MAT/LAW12 (3D_COMP), /MAT/LAW14 (COMPSO), /MAT/LAW15 (CHANG) and /MAT/LAW25 (COMPSH) | |
| VONM | Mean element von Mises stress. | |
| VSTRAIN | Volumetric strain | |
| VSTRAIN/I | Volumetric strain for each volume fraction I (for ALE multi-material laws: LAW20, LAW37, LAW51 and LAW151). | |
| USER |
User material (/MAT/USERij) law output for user-defined variable i. |
| BFRAC | Burn fraction | |
| COLOR | 1*vfrac1 + 2*vfrac2 + .... + last*vfracN (LAW51 and LAW151 only) | |
| DIV(U) | Volumetric dilatation rate | |
| K | Specific for turbulent energy in CFD | |
| LAW20 | DENS1 | Density for first material |
| DENS2 | Density for second material | |
| ENER1 | Specific Energy for first material | |
| ENER2 | Specific Energy for second material | |
| EPSP1 | Plastic Strain for first material | |
| P1 | Pressure for first material | |
| P2 | Pressure for second material | |
| QVIS1 | Artificial Viscosity for first material | |
| QVIS2 | Artificial Viscosity for second material | |
| SSP1 | Sound speed for first material. Only available with ALE material laws. | |
| SSP2 | Sound speed for second material. Only available with ALE material laws. | |
| TEMP1 | Temperature for first material | |
| TEMP2 | Temperature for second material | |
| VOLUM1 | Volume for first material | |
| VOLUM2 | Volume for second material | |
| MACH | Mach number (/MAT/LAW151 only) | |
| SCHLIEREN | Schlieren image (optical method widely used in CFD field). ALE material laws | |
| SSP | Sound speed. Only available with ALE material laws. | |
| TDET | Detonation time output. | |
| TVIS | Specific for turbulent viscosity in CFD | |
| VFRAC1,VFRAC2, VFRAC3,VFRAC4 | Volumetric fractions (for ALE multi-material laws: LAW20, LAW37 and LAW51) | |
| VORTX | Vorticity for ALE material in X direction. | |
| VECT | VEL | Velocity vectors at finite volume cell centroids. |
| ACC | Acceleration vectors at finite volume cell centroids. |
| Keyword3 | Keyword4 | Keyword5 | Description |
| TENS | DAMA | Cracks tensor at integration points for
/MAT/LAW24 only. If Keyword5 is blank, the mean value in the element is output. |
| EPSP |
Plastic strain tensor at integration points, only available
for /MAT/LAW24 with
Icap=2. If Keyword5 is blank, the mean value element is output. |
| STRAIN |
Strain tensor at integration points. If Keyword5 is blank, the mean value in the element is output. |
| STRESS |
Stress tensor at integration points. If Keyword5 is blank, the mean value in the element is output. |
/H3D/QUAD/VONM/H3D/QUAD/ENER
1 55 75/H3D/QUAD/USER/UVAR=12/H3D/QUAD/LAW20/DENS1Comments
- The syntax /H3D/ELEM/Keyword3/Keyword4/Keyword5 is also valid.
- When PART IDs are listed after the /H3D/QUAD line the specified results will only be output for those parts.
- To request integration point results, use /IR=i/IS=j notation where the options can be entered in any order.
- For failure criteria using different modes (mainly for composites), such as /FAIL/HASHIN, /FAIL/CHANG, and so on, these different modes can be output using the /H3D/QUAD/FAILURE option with the keyword MODE. You can choose to plot a specific mode using its number I (refer to the failure criterion documentation for mode number details), or all modes with ALL.
