/H3D/DT
Engine Keyword Writes the H3D results file at specified output frequency.
/H3D/DT
Tstart Tfreq Tstop
# start writing the h3d file at t=0.0 and create results every t=0.005
/H3D/DT
0.0 .005
# node velocity vectors
/H3D/NODA/VEL
# shell stress tensor for all integration points
/H3D/SHELL/TENS/STRESS/NPT=ALL
# shell plastic strain results at upper and lower integration points
/H3D/SHELL/EPSP/NPT=LOWER
/H3D/SHELL/EPSP/NPT=UPPER
/H3D/NODA/DMASS
# Equivalent strain rate for all elements
/H3D/ELEM/EPSD
# Solid element stress tensor. Mean value if element has multiple integration points.
/H3D/SOLID/TENS/STRESS
# compress results with max change of 0.01%
/H3D/COMPRESS
0.01
Definition
| Tstart | Start time to begin writing the H3D file. | |
| Tfreq | Interval time at which result data is written to the H3D file. | |
| Tstop | (Optional) Stop time to
end writing the H3D file. Default = 1e20 |
- The h3d file name is Runname.h3d, where Runname is the Run Name (/RUN)
- To define which results are saved in the h3d file see the /H3D/Element help options.
- It is possible to save only certain parts to the h3d file using the /H3D/PART option.
- The size of the h3d can be greatly reduced by using /H3D/COMPRESS.
