/H3D/SPRING
Engine Keyword Generate H3D contour output results for /SPRING spring elements.
/H3D/SPRING/Keyword3
#optional next line(s) that lists the parts to save results for
part_ID1... part_IDN
Definition
Keyword3 | Output types. | |
part_IDN | Optional list of part IDs for which results will be output. |
Keyword3 | Description |
AMS | Elements using AMS timestep due to /DT/CST_AMS. |
DAM1, DAM2, DAM3 | Damage in direction 1, 2 or 3. 3 |
DT | Element timestep. |
ENER | Specific energy density (internal energy divided by the element mass). |
EPSP | Plastic strain. |
F1, F2, F3 | Force in local coordinate system.
FORC | All forces and moments in local coordinate
system. F1, F2, F3, M11, M21, M31, M12, M22, M32. |
GROUP | Internal group identifier |
M11, M21, M31, M12, M22, M32 | Moment in local coordinate system.
MASS | Element mass |
OFF | Element status. Where the result output is:
# Spring element
timestep
/H3D/SPRING/DT
# Force and moment output for only parts IDs 356 and
293.
/H3D/SPRING/FORC
356 293
- The syntax /H3D/ELEM/Keyword3 is also valid.
- When PART IDs are listed after the /H3D/SPRING line the specified results will only be output for those parts.
- Damage in springs is defined as
the maximum value between time 0 and the current time of the displacement versus
failure displacement ratio:
For TYPE13 (/PROP/SPR_BEAM) springs, damage direction 1 is traction/compression, 2 and 3 are shear y and z.
For TYPE8 (/PROP/SPR_GENE) springs, damage directions 1, 2 and 3 are, respectively x, y and z.
