/H3D/PART
Engine Keyword Define which parts will be saved in the H3D file. The H3D file will only contain the model and result data for the listed part_IDs.
/H3D/PART
part_ID1... part_IDN
Definition
| part_ID1...part_IDN | The H3D file will only contain the model and result data for the listed part_IDs. |
The h3d file will only contain model and result data for
part_IDs=356, 293, 476,
489, 256
/H3D/PART
356 293 476 489 256
