/H3D/SPH
Engine Keyword Generate H3D contour output results for SPH.
/H3D/SPH/Keyword3/Keyword4
#optional next line(s) that lists the parts to save results for.
part_ID1... part_IDN
Definition
| Keyword3 | Output types. | |
| Keyword4 | Output types. | |
| part_IDN | Optional list of part IDs for which results will be output. |
| Keyword3 | Keyword4 | Description |
| DAM1, DAM2, DAM3 | Principal damage values in local cracking skew direction 1, 2 or 3 for material LAW24. | |
| DAMA | Maximum of damage over time of all /FAIL criteria acting on one material. Refer to the specific /FAIL law used for how damage is calculated. | |
| DENS | Density | |
| DT | Time step | |
| EINT | Internal energy ( eV) | |
| EINTV | Internal energy density ( e) | |
| EINTM | Specific internal energy (e) | |
| ENTH | Enthalpy (e+pV) | |
| ENTHV | Enthalpy density (e/V +p) | |
| ENTHM | Massic enthalpy (e + pV) / m | |
| DIAMETER | SPH Diameter | |
| DOMAIN | SPMD domain number of an element. | |
| ENER | Specific energy density (internal energy divided by the element mass). | |
| EPSP | Plastic strain for material laws greater than 28. | |
| FAILURE | ID=fail_ID or MODE= I or ALL |
Damage of a specific failure
criterion references by its optional identifier fail_ID defined in the Starter file. (for MODE output, refer to Comment 3). |
| GROUP | Internal group identifier | |
| MASS | Element mass | |
| NEIGHBOURS | Number of neighboring particle elements | |
| OFF | Element status. Where the result output is:
| P | Pressure | |
| SIGEQ | Equivalent stress based on a material’s yield criteria. Some examples of yield criteria are von Mises, Hill or Barlat. | |
| SIGX, SIGY, SIGZ, SIGXY, SIGYZ, SIGZX | Stress in specified direction. | |
| TEMP | Temperature | |
| TILLOTSON | Region identifier for Tillotson Equation of State (/EOS/TILLOTSON) | |
| VONM | von Mises stress | |
| USER |
User material (/MAT/USERij) law output for user-defined variable i. Also, requests USR output for some Radioss material laws. USR1 output is requested using UVAR=1. |
| TENS | STRAIN | Strain tensor for material laws greater than 28. |
| STRESS | Stress tensor | |
| DAMA | Cracks tensor at integration points for Material LAW24 only. |
# Stress tensor results for all integration
points
/H3D/SPH/TENS/STRESS# Specific energy density results for only parts IDs 356 and
293.
/H3D/SPH/ENER
356 293Comments
- The syntax /H3D/ELEM/Keyword3/Keyword4 is also valid.
- When PART IDs are listed after the /H3D/SPH line, the specified results will only be output for those parts.
- For failure criteria using different modes (mainly for composites), such as /FAIL/HASHIN, /FAIL/CHANG, and so on, these different modes can be output using the /H3D/SPH/FAILURE option with the keyword MODE. You can choose to plot a specific mode using its number I (refer to the failure criterion documentation for mode number details), or all modes with ALL.
