/H3D/BEAM
Engine Keyword Generate H3D contour output results for /BEAM beam elements.
/H3D/BEAM/Keyword3/Keyword4/Keyword5
#optional next line(s) that lists the parts to save results for.
part_ID1 ... part_IDN
Definition
| Keyword3 | Output types. | |
| Keyword4 | Output types. | |
| Keyword5 | Output types. | |
| part_IDN | Optional list of part IDs for which results will be output. |
| Keyword3 | Keyword4 | Keyword5 | Description |
| AMS | Elements using AMS timestep due to /DT/CST_AMS. | ||
| DT | Element timestep. | ||
| EINTV | Element internal energy per unit volume | ||
| ENER | Specific energy density (internal energy divided by the element mass). | ||
| EPSD | Strain rate | ||
| EPSP | NPT=I or ALL | Plastic strain. The integration point output NPT is only available for /PROP/TYPE18 (INT_BEAM). | |
| F1, F2, F3 | Force in local coordinate system.
| FORC | All forces and moments in local coordinate
system. F1, F2, F3, M11, M21, M31, M12, M22, M32 |
| FRACTION | MARTENSITE | NPT= i or ALL | Martensite fraction. Only available for /MAT/LAW71 + /PROP/TYPE18 (INT_BEAM). |
| TMAX | Maximum martensite phase fraction over time and over
integration points. Only available for /MAT/LAW71 + /PROP/TYPE18 (INT_BEAM). |
| GROUP | Internal group identifier | ||
| M11, M21, M31, M12, M22, M32 | Moment in local coordinate system.
| MASS | Element mass. | ||
| OFF | Element status. Where the result output is:
| SIGX, SIGY, SIGZ, SIGXY, SIGYZ, SIGZX | Stress in specified direction. | ||
| VONM | von Mises stress. |
| TENS | STRESS | NPT= i or ALL | Stress tensor for
/PROP/TYPE18 (INT_BEAM). (component XX, XY, ZX in elementary coordinate system) |
| STRAIN | NPT= i or ALL | Strain tensor for
| MAX | Maximum strain over all integration point (per element) max
of each component XX, XY, ZX. Only available for /PROP/TYPE18 (INT_BEAM). |
| TMAX | Maximum strain over all integration points and over time (per
element) max of each component XX, XY, ZX. Only available for //MAT/LAW71 + /PROP/TYPE18 (INT_BEAM). |
/H3D/BEAM/VONM/H3D/BEAM/ENER
356 293Comments
- The syntax /H3D/ELEM/Keyword3/Keyword4/Keyword5 is also valid.
- When PART IDs are listed after the /H3D/BEAM line, the specified results will only be output for those parts.
- The output location in
Keyword4 can be defined via:
NPT = integration points
- Output can be requested for a specific location number (I), ALL. The output locations are separated by a forward slash (/) and can be in any order.
