Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup
during the computation.
Generates animation files containing results according to the keywords specified. The keywords are specified in the
topics within Animation and Post-processing Output Files.
Engine Keyword Generates animation files containing a damage value for each layer of a shell element. The damage value is the maximum
of damage over time of all failure criteria associated to the material.
Engine Keyword Generates animation files containing the FLD failure zone factor for the FLD failure model as function of a shell
element integration point.
Engine Keyword Generates animation files containing shell tensor data for shell elements that use ply based composite properties,
/PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP.
Engine Keyword Generates animation files containing damage values for shell elements that use ply based composite properties,
/PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP. The damage value is the maximum of damage over time and of all failure criteria associated to the material.
Engine Keyword Generates animation files containing plastic strain for shell elements that use ply-based composite properties,
Engine Keyword Generates animation output for the time at which a shell element is deleted. The rupture time is output only for elements
which are deleted, due to a /FAIL criterion. Failure criteria built in materials are ignored.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling
or quasi-static), different options to control the implicit computation, different implicit time step method and
implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF)
and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature,
and so on) in a state file (STA-File).
/ANIM/SHELL/Restype Engine Keyword Generates animation files containing shell element data for the specified result. Options used for SHELL type of element.
/ANIM/SHELL/DAMA Engine Keyword Generates animation files containing a damage value for each layer of a shell element. The damage value is the maximum of damage over time of all failure criteria associated to the material.
/ANIM/SHELL/EPSP Engine Keyword Generates animation files containing plastic strain as function of a shell element integration point.
/ANIM/SHELL/FLDF Engine Keyword Generates animation files containing the FLD damage factor for the FLD failure model.
/ANIM/SHELL/FLDZ Engine Keyword Generates animation files containing the FLD failure zone factor for the FLD failure model as function of a shell element integration point.
/ANIM/SHELL/IDPLY Engine Keyword Generates animation files containing integer value, defining if a shell belong to a given ply.
/ANIM/SHELL/IDPLY/Restype Engine Keyword Generates animation files containing shell tensor data for shell elements that use ply based composite properties, /PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP.
/ANIM/SHELL/IDPLY/DAMA Engine Keyword Generates animation files containing damage values for shell elements that use ply based composite properties, /PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP. The damage value is the maximum of damage over time and of all failure criteria associated to the material.
/ANIM/SHELL/IDPLY/EPSP Engine Keyword Generates animation files containing plastic strain for shell elements that use ply-based composite properties, /PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP.
/ANIM/SHELL/IDPLY/PHI Engine Keyword Generates animation files containing angle between element skew and direction 1 orthotropy.
/ANIM/SHELL/NXTFACTOR Engine Keyword Generates animation files containing the instability factor of NXT failure model as function of a shell element integration point.
/ANIM/SHELL/PHI Engine Keyword Generates animation files containing angle between element skew and direction 1 orthotropy.
/ANIM/SHELL/SIG1H Engine Keyword Generates animation files containing the first normalized principal stress as function of a shell element integration point.
/ANIM/SHELL/SIG2H Engine Keyword Generates animation files containing the second normalized principal stress as function of a shell element integration point.
/ANIM/SHELL/TDEL Engine Keyword Generates animation output for the time at which a shell element is deleted. The rupture time is output only for elements which are deleted, due to a /FAIL criterion. Failure criteria built in materials are ignored.
/ANIM/SHELL/TENS Engine Keyword Generates animation files containing shell tensor data for a specified result.
