Engine Keyword Generates animation files containing the
FLD damage factor for the FLD failure model.
/ANIM/SHELL/FLDF/Keyword4
Definition
Field
Contents
SI Unit Example
Keyword4
Output location:
MEMB
Middle layer
UPPER
Upper layer
LOWER
Lower layer (number of integration points is equal to
one)
For a BATOZ shell element
(Ishell=12), the value is the average value of the Gauss points in the layer.
The values of FLD damage
factor is equal to the ratio of the actual major principal strain value over the
forming limit curve value:
Where, is the major principal strain at failure
limit from FLD (fct_ID in /FAIL/FLD).
The FLDF compares the and using the same .Figure 1.
FLDF may be greater than 1 if the option
/FAIL/FLD,
Ifail_sh
=4 is used. In this case, the damage factor is only
calculated for post-processing and no elements are deleted.
