Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup
during the computation.
Generates animation files containing results according to the keywords specified. The keywords are specified in the
topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling
or quasi-static), different options to control the implicit computation, different implicit time step method and
implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF)
and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature,
and so on) in a state file (STA-File).
/ANIM/Eltyp/Restype Engine Keyword Generates animation files containing element data for the specified result. Options used for beam, spring and truss element types.
/ANIM/Eltyp/FORC Engine Keyword Generates animation files containing force and moment data for the specified element type.
