/H3D/TRUSS
Engine Keyword Generate H3D contour output results for /TRUSS truss elements.
/H3D/TRUSS/Keyword3/Keyword4
#optional next line(s) that lists the parts to save results for.
part_ID1 ... part_IDN
Definition
| Keyword3 | Output types. | |
| Keyword4 | Output types. | |
| part_IDN | Optional list of part IDs for which results will be output. |
| Keyword3 | Description |
| AMS | Elements using AMS timestep due to /DT/CST_AMS. |
| DT | Element timestep. |
| ENER | Specific energy density (internal energy divided by the element mass). |
| EPSP | Plastic strain. |
| F1 | Force in local coordinate system.
| FORC | All forces and moments in local coordinate
system. F1, F2, F3, M11, M21, M31, M12, M22, M32 |
| GROUP | Internal group identifier |
| MASS | Element mass. |
| OFF | Element status. Where the result output is:
| SIGX | Stress in specified direction. |
| VONM | von Mises stress. |
| Keyword3 | Keyword4 | Description |
| TENS | STRAIN | Strain tensor (global) |
| STRESS | Stress tensor (global) |
# von-Mises
stress
/H3D/TRUSS/VONM# Specific energy density results for only parts IDs 356 and
293.
/H3D/TRUSS/ENER
356 293Comments
- The syntax /H3D/ELEM/Keyword3 is also valid.
- When PART IDs are listed after the /H3D/TRUSS line the specified results will only be output for those parts.
