Change the Vector Color by Value
From the Plot tools, click the Vector tool.
Figure 1. - From the Vector panel, click the Display tab (located in the middle of the panel).
Select Value from the Color by drop-down menu.
The Edit Legend button becomes enabled in the Legend tab.
From the Legend tab, click Edit Legend.
Modify the legend values and colors in the Edit Legend dialog.
