Change the Display Options
When tracing nodes or lines you can set the following Display Options.
Restriction: These options are disabled when tracing
components.
- Click the Color box to display the color palette, select a color, and click OK.
- Use the Thickness arrows to increment the line thickness from 1 to 10 pixels.
- Optional:
Activate the Move with tracking system check box to move
the trace with the entities relative to the tracking system.
Note: This option is enabled when a tracking system is activated in the Tracking panel.
