Clear Search String Field
- Click x on the right side of the search string field.
- Highlight the search string and press Delete or Backspace on the keyboard.
- Click .
Clearing the search string field displays the full browser tree.
View new features for Altair HyperWorks 2023.1.
Animation files are opened using the Load Model panel.
Use the Measure tool to measure various distances and angles between entities.
The Results Browser allows you to view the model structure while providing find, display, and editing control of entities.
Entity specific views are available within the Results Browser for the following entities: Assembly, Components, Load Cases, Models (Files), Includes, Results, Sets, and Parts.
The Results Browser contains several ways to filter results data to display specific entities in the browser.
The Local Display Controls affect the visual style of individual entities (such as shaded or wireframe).
Clicking the right mouse button on a folder or entity/item within the browser’s tree structure allows you to change a variety of options using the browser context-sensitive menu.
Use the Entity Editor section of the Results Browser to view and edit various entity conditions/properties.
Entities can be selected using input collectors or the quick window selection method.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
