Counting Layers
The Count layers option in the Contour panel and Iso panel allows you to calculate and display how many layers/plies are in each element.
The Count option can be used in conjunction with the Layer filter and the Value
filter options (located in the middle of the panel), in order to further specify or define
the plies/layers to be included in the count results (see the examples below).
The tables below illustrate how the Count option and the Value Filter work
together:All layers are included in the count and other calculations (Max, Min,
etc.).
Only the layers which are less than or equal to 0.4 (the Value filter setting) are
included in the count and other calculations (Max, Min, etc.).
Only the layers which are greater than or equal to 0.4 (the Value filter setting) are
Only layers 1, 3, and 5 (selected using the Layer filter) which are greater than or
equal to 0.4 (the Value filter setting) and are included in the count and other calculations
(Max, Min, etc.).
