Edit a Curve with File as a Data Source
- From the Define Curves dialog, select a curve from the list or pick a curve from the window.
 - Click on the corresponding vector radio button to edit the X or Y data vector.
 - Select or enter the new data for the vector.
                Click Apply.
                The changes to the curve are reflected in the HyperGraph window.
