Display the Curves Tab
From the Expression Builder, use the Curves tab to reference curves.
From the Define Curves dialog, select tab.
The browser displays a tree structure for the pages, windows, and curves.
- Click Direct Insert or Use In Expression to insert the range in the Vector or Expression field, respectively.
