Define a Range
- From the Define Curves dialog, select .
- From the Templex functions list, select the rangepair function.
- In the Entity Editor, under Parameters, enter values for minrange and maxrange for the start and end points for the range of values, respectively.
Click Direct Insert or Use In
Expression to insert the range in the Vector or Expression
field, respectively.
See rangepair in the Templex and Math Reference Guide for more information.
