2026
Plot data can be post-processed using both HyperMesh and HyperGraph.
Use the Chart Manager to plot your analysis results.
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Use the Chart Manager to create and visualize plots based on HyperMesh results, data exported from a HyperMesh table or the Matrix Browser, or direct input. You can also save your plots to a session.
Open the Chart Manager from the Post ribbon or the Model Browser.
Use the New Chart dialog to plot your results.
Save charts to a session file.
Context menus are floating menus that are accessed by right-clicking on elements in the user interface. They provides immediate access to a short list of commands that are contextually relevant to the selection.
