Export Files
Export various file types from the selected client to another format.
Use the Custom option to export models using your own custom-built export translator, or export models using a translator provided with the installation but which is not directly accessible via the default Export file types.
Do one of the following:
- From the menu bar, select .
- Press Ctrl + E.
Depending on the client you are using, the following file types can be exported: models, geometry, solver decks, BOMs, connectors, H3D binary files, curves, markers, output text, CSV tables, and custom data files. - In the Export File dialog, enter a name for the file and save it to your working directory.
- If needed, define any options in the Export Options dialog and then click Export.
