- HM_ASSEM
Import comment to sort and organize entity types into HyperMesh.
 - HM_COMP_BY_PROP
 - HMASSOC
Associate an existing node to an existing surface.
 - HMASSEM
 - HMASSEM_COMP_ID
 - HMASSEM_ID
 - HMBEAMSEC
Import comment to sort and organize property types and info into HyperMesh.
 - HMBEGINDOC
Import comment that indicates the beginning of the model documentation into HyperMesh.
 - HMCOMP
 - HMCOMP_ID
Assign property directly or indirectly to elements and organize the elements.
 - HMCONT
Continuation card for the HMBEAMSEC card.
 - HMCURVE
Preserves the style information for load curves.
 - HMDB
Points to a material database file for the solver.
 - HMDISPLAY
Defines the base location of a velocity load in HyperMesh.
 - HMDPRP
Import comment to sort and organize design properties into HyperMesh.
 - HMENDDOC
Import comment that indicates the end of the model documentation into HyperMesh.
 - HMENT
Preserves the ADMASS card upon import in Radioss.
 - HMERROR
Export comment that detects a problem upon export.
 - HMFIXEDSURFPOINT
Describes weld points for the automesher.
 - HMFOOTERBEGIN
Import comment that indicates the beginning of the footer for the deck.
 - HMFOOTEREND
Import comment that indicates the end of the footer for the deck.
 - HMFLAG
HMFLAG
 - HMGPMV
Defines a conduction group identification number in HyperMesh.
 - HMMOVE
Change the input component of an element.
 - HMNAME
 - HMNAME ASSEM
 - HMNAME COMP
 - HMNAME GROUP
 - HMNAME MAT
 - HMNAME PROP
 - HMNAME SET
 - HMORIENT
Defines a global origin for the analysis.
 - HMOUTPUT
Gives the date and time that the deck was written and serves as a signal that the         deck was created by HyperMesh.
 - HMPLOTELM
Preserves plot element information in solvers that do not support plot         elements.
 - HMREFSYSTEM
Re-associate nodes/systems with their local systems.
 - HMSET
Import comment to sort and organize entity sets into HyperMesh.
 - HMSET_SET_ID
 - HMSETTYPE
 - HMSUPPORT
Import comment to associate support loads into a load collector in HyperMesh.
 - HMTAG
Preserves tag information in solvers that do not support tags.
 - HMUNSUPPORTED
Import comment to indicate to the reader that information in this section should be         retained in the unsupported area of HyperMesh.
 - HWCOLOR
Import comment to color an entity in HyperMesh.
