Convert Units
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
Restriction: This tool is only supported in the
LS-DYNA and Radioss
interfaces.
From the Model ribbon, click the Units tool.
Figure 1. -
Click
on the guide bar.
Select the source unit system and the target unit system.
The supported units are:
- N, m, s, kg
- N, mm, s, T
- N, mm, ms, g
- kN, mm, ms, kg
Click Convert to automatically scale the full FE model
keywords data.
Note: LS-DYNA materials starting from *MAT_101 are not yet fully validated and may present some issues during the conversion, except for: *MAT_103, *MAT_124 to *MAT_126, *MAT_169, *MAT_181, *MAT_183, *MAT_240.
