Create Thickness Constraint Inputs
Use the Thickness Constraint tool to create a design variable based on an existing Topology Optimization minimum dimension value.
Note: To create a thickness constraint input, an initial Minimum value must be present on the Topology Optimization design variable (DTPL).
  1. From the Design Explorer ribbon, click the Thickness Constraints tool.
    Thickness Constraint input values can be entered in one of the following ways:
    • As a continuous range of values, where the lower and upper bounds are specified as a percentage plus or minus its nominal value.
    • As a continuous range of values, where the lower and upper bounds are specified specifically.
    • As a list of discrete values.
  2. Optional: Select a design space to apply the design variable on.
  3. In the microdialog, select how you would like to define the input values.
  4. Specify the lower and upper bounds or specify a list of valid discrete values.
  5. Click Create.
