Create Mass Targets Inputs
Use the Mass Targets tool to create a design variable based on an existing Topology Optimization constraint.
From the Design Explorer ribbon, click the
Mass Targets tool.
Figure 1. Mass Target input values can be entered in one of the following ways:
- As a continuous range of values, where the lower and upper bounds are specified as a percentage plus or minus its nominal value.
- As a continuous range of values, where the lower and upper bounds are specified specifically.
- As a list of discrete values.
- In the microdialog, select how you would like to define the input values.
- Specify the lower and upper bounds or specify a list of valid discrete values.
Click
Create.
