Create Draw Inputs
Use the Draw tool to create a design variable based on draw directions to be considered in the generative design exploration.
Note: For Generative Design explorations, only draw types none and single will be
considered.
From the Design Explorer ribbon, click the
Draw tool.
- Optional: Select a design space to apply the design variable on.
In the Draw Directions dialog, add rows to the table for
each draw direction to be considered by completing one of the following
options:
- Click None, X, Y, Z, -X, -Y, or -Z.
- Click Add Row to define a draw direction based on the selection of a plane in the modeling window.
- Click OK.
