Results of LS iron losses computation on point
Computation results
The computation of LS iron losses on point gives the following results
Curve
"CURVE_LOSS_POINT_i" curve can be displayed automatically and is stored in the tree in the area Postprocessing > Curve > 2D Curve (I/O Parameter)
It contains three curves:
  • the volume density of instantaneous losses on the point versus time "DVOL_LOSS_LS_INST"
  • the magnetic flux density on point versus time "BMAG1_LS”
  • the magnetic field on point versus time "HMAG1_LS”
Remark: the last two curves show the hysteresis cycle on the considered point.
Result
The results are automatically displayed in the data tree in the area Postprocessing > Result > Iron losses Result.
The results include:
  • Volume density of average iron losses over a period on the point (in W/m3)
  • Volume density of iron losses energy over a period on the point (in J/m3)
Figure 1. Hysteresis cycle in the middle of the stator tooth on a permanent magnet machine.
