Isotropic / anisotropic soft magnetic material: analytic saturation curve
Presentation
This model defines a nonlinear B(H) dependence for an isotropic material, taking the saturation into consideration.
Mathematical model
This model is composed of a straight line and an arctangent curve.
The corresponding mathematical formula is written as:
where:
  • μ0 is the permeability of vacuum, μ0 = 4 π 10-7 H/m
  • μr is the initial relative permeability of the material (at the origin)
  • Js is the magnetic polarization at saturation (T)
The shape of this B(H) model is given in the figure below.
Anisotropic material
For an anisotropic material, this model consists in a set of three equations, one per 3D-space direction.
This model is available when the following conditions are satisfied:
  • 2D applications (2D plane domain): Magneto Static / Transient magnetic
  • regions: magnetic non conducting, solid conductor
