Isotropic / anisotropic soft magnetic material: linear approximation
Presentation
This model defines a linear B(H) dependence without taking into consideration the saturation phenomenon for an isotropic or anisotropic material. It can be utilized for fields of low values, as long as the saturation knee is not reached.
Mathematical model
This model is a straight line.
The corresponding mathematical formula is written as follows:
Β(Η)=μ0μrΗ
where:
- μ0 is the permeability of vacuum, μ0 = 4 π 10-7 H/m
- μr is the relative permeability of the material
The shape of the B(H) dependence is given in the figure below.
Anisotropic material
For an anisotropic material, this linear model consists in a set of three straight lines, one per 3D-space direction.
