Geometry importation: IGES / STEP standard format
IGES and STEP formats
The standard formats IGES / STEP enable the direct importation of geometry. These two formats enable the importation of complex faces (starting from version 9).
Warning: These formats are not available on the UNIX systems.
Conversion
The entities of initial file in IGES / STEP formats are read and converted into Flux entities as in table below.
Entities of initial file are converted into …
points points defined by parameterized coordinates
lines
lines of type:
  • segment defined by extremity points
  • arc defined by origin, intermediary and extremity points
  • curve (for the unspecified lines)
faces
faces of type:
  • automatically defined by plane, cylindrical or conical surfaces
  • uneven type, defined by any kind of surfaces
Options for conversion
The choice of the general options for conversion is not proposed to the user at the time of the importation. Flux imposes the default options (Coordinate system: IGES_i / STEP_i; length unit: the meter; precision: automatic).
