Geometry importation: "standard formats"
Important: Since Flux 2026, for strategic reasons, the external geometric kernel library (ACIS), which allows to build a geometry via the modeler and to export/import CAD files, has been removed.
The impact of removal of Modeler and CAD import/export is mainly for Flux 3D (which is also removed in Flux 2026), but also for Flux 2D. Flux 2D is still accessible in Flux 2026, but CAD import/export is now not possible in Flux 2D also, except via a standards DXF import / export.
Introduction
This section relates to conversion during the importation of geometry.
Formats
The formats which enable the geometry importation are following:
  • standard format: DXF (Draw eXchange File)
  • proper format: FBD (Legacy Flux 2D geometry)
Contents
