Import geometry
Import
To import geometry from XXX file:
Step Action
1
Activate the command via the menu Import > Import geometry and click on Import geometry from XXX file
→ A dialog box Import geometry … is opened.
2
Select a file:
  • click on button
    → dialog box Open is opened.
  • seek the file and click on it
  • click on Open
→ The complete path of the file is registered in the text zone XXX file to import of the dialog box Import geometry … .
3
Choose the options for data conversion:
  • general options: coordinate system, length unit, precision
  • specific options
4
Confirm:
  • click on OK
→ A geometrical figure appears.
