Geometry importation: DXF standard format
Conversion
The entities of initial file in DXF format are read and converted into Flux entities as in table below.
| Entities of initial file | are converted into … |
| POINT | points defined by parameterized coordinates |
| LINE | lines of segment type defined by extremity points |
| POLYLINE | N lines of segment type |
| ARC, CIRCLE | lines of arc type defined by origin, intermediary and extremity points |
| 3DFACE | faces of automatic type, with triangular shape, defined by a plane surface |
Options for conversion
The options for conversion proposed to the user are of two types: general options for conversion available for all formats
- particular options, specific to the format
Structure of a DXF file
A DXF file consists in 4 sections:
- HEADER
- TABLES
- BLOCKS
- ENTITIES
Only the ENTITIES and BLOCKS sections are interpreted by Flux.
| Section | Contents |
| ENTITIES | information about the entities (geometrical data) : points, lines, faces ... |
| BLOCKS | information about the texts, sizes, etc. (data of pictures) |
Specific options
The options for conversion specific to the DXF format are presented in the table below.
| Option | Choice | Description |
| Import in 3D or convert in 2D | 3D (by default) | Flux imports the data in 3D |
| 2D | the user choose to convert the initial file in 2D | |
| Convert the ENTITIES | yes (by default) | Flux reads and converts data from the ENTITIES section |
| no | Flux does not read the data contained in the ENTITIES section (ignored data) | |
| Convert the BLOCKS | no (by default) | Flux does not read the data contained in the BLOCKS section |
| yes | Flux reads and converts the data from the BLOCKS section | |
| Import the EXTENDED ENTITIES* | no (by default) | the DXF file is imported in standard format |
| yes | the DXF file is imported with the extended data * |
