3D grid: definition (structure)
Definition
A 3D grid is defined by:
  • a name (and a comment)
  • a type
  • a coordinate system for definition
  • an origin (in a coordinate system for definition)
  • specific characteristics belonging to a type
  • attributes of color and visibility
Name
The name to identify the 3D grid is set by the user during the creation of this one.
A comment (optional) can be added to the name.
Type of 3D grids
The different types of 3D grids and the characteristics useful for their description are presented in the table below.
Type Characteristics
All types 3D grid origin coordinates coordinate system for definition
Cube
length of the cube edge
number of elements along the length
Parallelepiped
dimension along positive X
dimension along negative X
number of elements along X
dimension along positive Y
dimension along negative Y
number of elements along Y
dimension along positive Z
dimension along negative Z
number of elements along Z
Cylinder
radius
number of elements along the radius
number of elements along θ
Part of cylinder
internal radius
external radius
minimal θ
maximal θ
minimal φ
maximal φ
number of elements along φ
Sphere
radius
number of elements along θ number of elements along φ
Length and angle units
Length and angle units are those associated with the coordinate system.
