Mesh point: definition (structure)
Definition
A mesh point is defined by:
- a name (and a comment)
- a type
- specific charateristics, depending on the type
- a color
Name
The name to identify the mesh point is set by the user during the creation of this one.
A comment (optional) can be added to the name.
The types of mesh point are presented in the following table.
| Type | Description |
| Uniform | Mesh point using a fixed value determined by the user |
| Dynamic* | Mesh point using a dynamic value: the lowest weight corresponds to the length of the shortest incident line of the project. |
Value
The mesh point value is defined using an algebraic expression that can contain:
- constants
- geometrical parameters
- basic mathematical functions using operators: +, -, *, /, ( )
- usual mathematical functions admitted by FORTRAN.
The mathematical functions are described in section Functions .
