Creation of visualization volume elements by selection plane
In the Flux3D menu Mesh, it is possible to visualize the volume mesh by a selection plane. This command allows you to create all the visualization volume elements on the same side of the plane.
Create visualization volume elements by selection plane
In order to vizualize the volume mesh by a selection plane, follow these instructions:
- Select the menus
- Select the 3 points defining the planeAttention: The order of point selection determines the display side.
- Select the list of volumes whose volume elements will be excluded from the display (by default this list is empty).
Illustration of a volume mesh visualization by selection plane:
