Analytic saturation curve * exponential function of T
Presentation
This model defines a B(H) behavior law:
  • nonlinear (taking the saturation into consideration)
  • for an isotropic material
  • through a saturation magnetic polarization Js and a magnetic susceptibility χ (where χ = μr - 1) which decrease in an exponential way when the temperature increases
Mathematical model
This model is a combination of a straight line and a nonlinear equation (based on arctangent function), where the saturation magnetic polarization Js and the magnetic susceptibility χ decrease in an exponential way when the temperature increases. The temperature coefficient coeff(T) appears only as a multiplying factor of the arctangent function, while not in its argument because it simplifies being applied to both χ and Js.
The corresponding mathematical formula is written:
where:
  • μ0 is the permeability of vacuum; μ0 = 4 π 10-7 H/m
  • μr0 is the relative permeability of the material (at the origin) for T = 0 °C
  • Js0 is the saturation magnetic polarization for T = 0 °C (T)
  • coeff(T) is the temperature coefficient function which describes how the saturation magnetic polarization Js and the magnetic susceptibility χ decrease when the temperature increases
The shape of B(H) curve for a given temperature is presented in the figure below.
An example of this B(H) analytic saturation curve * exponential function of T is presented in the figure below, where the Curie temperature TC of the material and the temperature constant C are respectively TC = 727 °C and C = 100 °C.
