Analytic saturation curve + knee adjustment * exponential function of T
Presentation
This model defines a B(H) behavior law:
  • nonlinear (taking the saturation and the knee adjustment into consideration)
  • for an isotropic material
  • through a saturation magnetic polarization Js and a relative permeability μr which decrease in an exponential way when the temperature increases
Mathematical model
This model consists, like the previous one, of a combination of a straight line and a nonlinear equation (based on square root function), where the saturation magnetic polarization Js and the relative permeability μr decrease in an exponential way when the temperature increases. The temperature coefficient coeff(T) appears as multiplying factor of the square root function, as well as in its argument through the quantity Ha.
The corresponding mathematical formula is written:
with:
where:
  • μ0 is the permeability of vacuum; μ0 = 4 π 10-7 H/m
  • μr0 is the relative permeability of the material (at the origin) for T = 0 °C
  • Js0 is the saturation magnetic polarization for T = 0 °C (T)
  • a is the knee adjustment coefficient (a > 0 and a ≠ 1); the smaller the coefficient, the sharper the knee is
  • coeff(T) is the temperature coefficient function which describes how the saturation magnetic polarization Js and the relative permeability μr decrease when the temperature increases
The shape of B(H) curve for a given temperature and several knee adjustment coefficients is presented in the figure below.
An example of this B(H) analytic saturation curve + knee adjustment * exponential function of T is presented in the figure below, where the Curie temperature TC of the material and the temperature constant C are respectively TC = 727 °C and C = 500 °C.
