Magnet (unidirectional): demagnetization curve (HcB, Br) + knee
Presentation
This model (Nonlinear magnet described by HcB and Br module, plus knee adjustment) defines a nonlinear B(H) dependence. Non-linearity is considered in the direction of magnetization whereas the model's behavior is linear in the transversal directions.
This magnet model is noted as unidirectional because the mathematical model and the direction of magnetization are dissociated (About orientation of magnets). The mathematical model defines the demagnetization curve, while the direction of magnetization is defined by the orientation in the region (Orient materials in massive regions: volume (3D) / face (2D)).
Mathematical model
The mathematical formula used in Flux for the demagnetization curve is:
For H ≥ -HcB
with
where:
  • μ0 is the permeability of vacuum, μ0 = 4 π 10-7 H/m
  • μr is the relative permeability of the material (for H = -HcB)
  • HcB is the normal coercivity (A/m)
  • a is the knee adjustment coefficient (a > 0 and a ≠ 1), enabling to adjust the shape of the curve "knee" for a better approximation of the experimental curve. The smaller the coefficient, the sharper the knee is.
  • J's is computed by bisection method from Br, HcB and μr, knowing that (T)
The shape of the B(H) dependence in the direction of magnetization is given in the figure below:
In transversal directions one can write:
where μr┴ is the transversal relative permeability.
Direction of magnetization
The various possibilities provided to the user are the same ones as those presented in § Magnet (unidirectional): linear approximation.
