Assign a mesh generator to faces / volumes
To assign a mesh generator to faces / volumes:
Step Action
1 Activate the Assign mesh generator command (see next block)
→ An assignment box is open.
2
Fill out the assignment box:
  • choose a mesh generator in the list of mesh generators
  • click on OK
→ The mesh generator is assigned to faces / volumes.
3
Go on assignment:
  • go to step 2
Quit the assignment sequence:
  • click on Cancel
Activate the command
To activate the Assign mesh generator command, which requires data selection, choose one of the methods presented in the figure below:
Note: Reminder:
  • To open a contextual menu, use the right button of the mouse.
  • For multiple selections, keep the Ctrl key pressed.
