Assign a mesh generator: about
Mesh generator assignment
Choice of mesh generators on geometric entities (of face or volume type) is called assignment of mesh generators.
Operation mode
Two operation modes provided are as follows:
| Mode | is used to assign a mesh generator to … |
| completion | a group of faces / volumes |
| modification | some faces / volumes |
Completion mode: specific features
In completion mode the entities are made invisible in the graphic scene during the assignment, which allows a fast and effective assignment of the groups of faces and groups of volumes.
Updating
After a mesh generator is assigned to the face / volume, the Mesh tab of the face / volume dialog box is updated.
