Embed provides on-chip peripheral blocks to allow you to AMD64, Arduino, Raspberry Pi, STMicroelectronics, and Texas Instruments boards and microcontrollers.
See Also:
ADC10/12
Analog Comparator DAC
Analog In
Analog Input
CAN Receive
CAN Transmit
CAN Transmit Ready
Comparator
COMP
DAC
DAC12
Digital In
Digital Input
Digital Out
Digital Output
DMA Enable
eCAP
eCap PWM
ePWM
ePWM Action
ePWM Action Write
ePWM Chopper
ePWM Force Action
ePWM Force Action Write
ePWM for simulation
eQEP
eQEP for simulation
Event Capture
Extern Definition
Extern Function
Extern Read
Extern Write
Full Compare Action
Full Compare PWM
Get CPU Usage
GPIO In
GPIO Input
GPIO Out
GPIO Output
Hall Sensor
HRCAP
I2C Read Buffer
I2C Start Communication
I2C Write Buffer
JSON Create String
JSON Get Value
Monitor Buffer Empty
Monitor Buffer Read
Monitor Buffer Write
MQTT Publish
MQTT Subscribe
Op Amp
PWM
PWM for simulation
Quadrature Encoder
Read Target Memory
SD16
SD16A
segmentLCD
Serial UART Read
Serial UART Write
Set PWM Mode
Sigma Delta Filter Module
SPI Read
SPI Write
UDP Read
UDP Write
Target Interface
Watch Dog
Web Server
