Selective Saves
Selective saves allow you to select which attributes are saved and how often by defining partial saves. Using selective save can greatly reduce simulation data file sizes and allow you to run even larger simulations.
- In the Simulator Settings dialog box, specify the following details:
Specify a value for Full Data Save Every to set the
frequency of full data saves.
Selective save works by combining full saves (where all data is written out) and partial saves (where only selected data is written out) to create smaller data sets. For example, assume you have a simulation with a total time of 10 seconds that writes-out every 1 second. By default, this creates a full save of all simulation data every second.
0s 1s 2s 3s 4s 5s 6s 7s 8s 9s Full Full Full Full Full Full Full Full Full Full For example, setting the Full Data Save Every option to 3 intervals results in a full save only every 3 seconds (the first write-out is always a full save).0s 1s 2s 3s 4s 5s 6s 7s 8s 9s Full Partial Partial Full Partial Partial Full Partial Partial Full - Click Configure Save.
In the Data Save Configuration dialog box, select the
Particle, Geometry, and Interaction Attribute Data tabs to save in a partial
save.
Table 1. Particle Data Data Group Attribute Data Base Particle Data ID Position Orientation Number of particles Volume Voidage Mass Moment of Inertia Potential Energy Velocity Velocity Kinetic Energy Angular Velocity Angular Velocity Rotational Kinetic Energy Total Energy Force and Torque Compressive Force Total Force Torque Table 2. Geometry Data Data Group Attribute Data Base Geometry Data ID Position Surface Normal Node Number of Geometry Elements Velocity Angular Velocity Force and Torque Compressive Force Total Force Torque Table 3. Interaction Data Data Group Attribute Data Contacts (Particle-Particle) All particle-particle contact attribute data Contacts (Particle-Geometry) All particle-geometry contact attribute data Collisions (Particle-Particle) All particle-particle collision attribute data Collisions (Particle- Geometry) All particle-geometry collision attribute data Custom Properties All interaction-based custom property data The Data Save Configuration dialog box also displays an estimate of the per-particle or per-triangle reduction in data size for each Time Step. -
Select the appropriate checkbox to include an attribute in the save. Any other
required attributes will also be enabled.
Optionally, you may not select a data group to exclude related attributes.Note: If you stop the simulation earlier and then switch to EDEM Analyst, the current Time Step will be a full save irrespective of the full save interval.
