Use the Command Window
The Compose Command Window allows you to execute OML commands interactively.
To display the content of a variable, use the disp()
statement.
> A = [1,2,3]; > disp(A) [Matrix] 1 x 3 1 2 3 -
Use the additional options for managing commands:
- Recall previous commands by using the up and down arrow keys.
- Drag commands from the Command History window to execute them.
- Double-click commands in the Command History window to execute them.
