Radiation
Radiation modes
This panel allows describing the parameters defining the radiation phenomenon existing between the machine and the external world.
Two ways are proposed to define the radiation: an automatic and a user one.
| 1 | Auto mode: This mode allows to set the external emissivity automatically. |
| 2 | User mode: This mode allows to set the external emissivity manually. |
User mode
The user mode allows to set the emissivity between the frame and the external air. This value must be established between 0 and 1. The default value is 0.8.
