Topics Discussed in this Example
The topics discussed in this example are:
  • Creating a co-site interference solution.
  • Adding equipment to the antennas.
    • Importing equipment definitions from the equipment catalog.
  • Requesting interference results of interest.
  • Mitigating the interference by adding additional equipment to the transmitters and receivers.
Note: Follow the example steps in the order presented, as each step uses its predecessor as a starting point.
