Project to CAD
Project to CAD is used to project the nodes of a FEM entity onto the corresponding CAD entity.
Select
Projection of FEM nodes can be done based on- Model
- Body
- Face
- Edge
The user needs to select the FEM and the corresponding CAD entities. It is to be noted that the input FEM entity gets locally modified. Undo operation is also supported.
Project mesh edge nodes to CAD edges
This option can be turned OFF to prevent edge distortions caused by projection when the mesh model has been extensively modified and has significant topological differences from the original CAD model.
Options
Projection options is available only for Model and Body based projection. The user can either ignore projections of nodes for few faces or include few faces.Example
Few nodes that were out of geometry are projected on to the geometry using Face based projection.
Before Projection
After Projection
